Multiple Nios in Max 10
There are already some reference designs available to run dual boot on MAX 10. Please check the followings:
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dual-boot-design-example-max10-de10-lite/
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dual-boot-design-example-for-deca-board/
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dual-boot-development-kit/
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dual-configuration-and-pwm-controls/
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dual-boot-design-example-for-odyssey-development-kit/
https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/dual-core-nios-ii-project-with-protected-memory-regions/
https://fpgacloud.intel.com/devstore/platform/17.1std.1/Standard/dualboot-design-example/
- PGigl7 years ago
Do any of these walk through the process of creating the Pof using 2 hex files? I tried to open the user guides on a couple of these, but the links seem to be broken! Can you provide a link to a user guide that shows how to do this?
- PGigl7 years ago
ALso, I am not looking for dual boot- I am looking at dual processors!! The only one that looks close is the dual-core-nios-ii-project-with-protected-memory-regions. I looked at the manual for this and it does not show how to make the final programming image with the two hex files. The just program the FPGA with the base fpga image and then run the debugger. There is no mention of making the POF file with the two elf/hex files.
