12 years agoThe restriction is that one .aocx file can be paired up to a cl_program. So if you want to have multiple kernel files that get swapped in and out just make sure you have multiple cl_program objects in your host code. You will still need to compile each .cl file individually using aoc.exe since there is no way to pass in multiple kernel files (you often want to compile them with different flags anyway).
One word of caution is that each time the OpenCL runtime needs to swap out hardware it will copy any live buffers in the FPGA up to the host and restore them after the kernel hardware (.aocx file) has been configured into the FPGA. So if you host leaves a bunch of unused buffers in the FPGA instead of freeing them then you'll be copying data back and forth when switching between cl_program objects. Also there is an overhead for configuring the hardware as well so when you are determine which kernels go into each .cl file, think ahead about this overhead and how your host will be running the kernels and try to group kernels into the same .cl file to help minimize the overhead whenever possible.
