12 years agoDelaration of the variable
reg signed taps ;
reg signed initial_additions ; // addition between two taps, only used in symetric filters
reg signed multiplications ; // initial_additions * coefficients
reg signed final_additions ; // two multiply results added together and registered
reg signed final_result; // sum of final_additions
wire signed final_result_temp;
wire signed coefficients ;
wire signed Counter_Result=0;
This the modified section
always @ (posedge clk or posedge reset)
begin
if (reset)
begin
final_result <= 0;
end
else if (clear == 1)
begin
final_result <= 0;
end
else
begin
final_result_temp<=final_result_temp+final_additions;
Counter_Result<=Counter_Result+1;
if (Counter_Result==((NUM_OF_TAPS/4)-1))
begin
final_result <= final_result_temp;
final_result_temp <= 0;
Counter_Result=0;
end
end
end
Here i use final_result variable scfifo the_output_fifo (
.aclr (reset),
.sclr (clear),
.clock (clk),
.data (final_result),
.almost_full (fifo_half_full),
.empty (fifo_empty),
.q (source_data),
.rdreq (read_fifo),
.wrreq (tag) // tag delay pipeline matches when valid data pops out of "final_result"
