12 years ago --- Quote Start --- Hi, I have this code
reg signed final_additions ; // two multiply results added together and registered
reg signed final_result; // sum of final_additions
wire signed final_result_temp;
wire signed coefficients ;
genvar Counter_Result;
generate
for(Counter_Result = 0; Counter_Result < ((NUM_OF_TAPS/4)-1); Counter_Result=Counter_Result+1)
begin : the_final_reult
always @ (posedge clk or posedge reset)
begin
if (reset)
begin
final_result_temp<= 0;
end
else if (clear == 1)
begin
final_result_temp <= 0;
end
if (Counter_Result == 0)
begin
final_result_temp <= final_additions;
end
else
begin
final_result_temp <= final_result_temp+final_additions;
end
end
end
endgenerate
begin
if (reset)
begin
final_result <= 0;
end
begin
final_result <= 0;
end
else
begin
final_result <= final_result_temp;
end
end
When i launch the compilation i get this error: Error (10028): Can't resolve multiple constant drivers for net "final_result[33]" at custom_FIR.v(255). How can i correct this erros. Thank you --- Quote End --- Do you drive "final_result" anywhere else not shown in your code? I haven't done verilog for years but I believe you don't need generate as you are driving the same signals several times. since you want to add up all the additions in an accumulator in real time then I will run a hard counter and add according to its value. The generate statement is a compile time issue, isn't it?
