18 years agoHello,
I think your design is nearly correct. But when you assign etat_suiv (next_state) in the combinational case construct, then you must assign etat_pres (current_state) in the clock synchronous process:process (clk)
begin
if rising_edge(clock) then
etat_pres <= etat_suiv;
end if;
end process; Personally, I prefer more simple state machine constructs inside a single clock synchronous process (Mealey type), but that's a matter of taste, I believe. Regards, Frank
