18 years ago --- Quote Start --- And I want that the block will running block after block. --- Quote End --- What do you mean? Which blocks? The blocks in your CASE statements are mutually exclusive because etat_pres can't take 2 values at one time. So what's the problem. Is it the first time you are writing some VHDL code?
