12 years agoWhat you need to do, is set the setup and hold times either "from" the input registers or "to" the output registers (or from and to if you only want specified paths.
set_multicycle_path -from [get_keepers {my_input_regeres} ] -to [get_keepers {my_output_registers}] -setup N set_multicycle_path -from [get_keepers {my_input_regeres} ] -to [get_keepers {my_output_registers}] -hold N-1 This is when enable is high once every N clocks. I notice the data out from your blcok is not registered - any reason?
