11 years agomSGDMA: Incorrect operation but the behavior changes when SignalTapII is inserted.
Hi all, Please help me. I am using two mSGDMA modules to read and write DDR3 on DE5-NET board with quartus ii ver 14.1.1. The mSGDMA is of the modules of Qsys ver 14.1. The problem that ...
11 years ago --- Quote Start --- Hi, I found that 1) mSGDMA core gets easier to operate correctly when I turn off "burst enable." 2) However, sometimes the mSGDMA with burst disabled can fail to transfer data. With signal-tap II, I found that this failure is caused by incorrect latch to length_counter and/or address_counter in Write_master. For example, when descriptor port of Dispatcher receives 0x0001_4000 as a length, 0x0000_4000 is written into the length_counter in Write_master of a ST-MM mSGDMA. Since MM-ST mSGDMA sends 0x0001_4000 elements of data to the ST-MM mSGDMA, the former mSGDMA is kept busy. And then the next DMA transfer fails. "src_write_master_data" (a command from Dispatcher to Write_mater) has a length of 0x0000_4000, instead of 0x0001_4000. So Dispatcher wrongly works. I doubt the_write_signal_breakout module in the_descriptor_buffers module. --- Quote End --- I solved the problem by implementing my own fifo_with_byteeable that does not use alt_syncram with byteenable. So I conclude that incorrect write with byteenable of the altsyncram on Sratx V 5SGXEA7 causes the problem. If you want to read my fifo_with_byteenables, please let me know. Mickycat
