10 years agoMore than one USB Blaster connected to a host system
Has anyone been successful hooking up more than one USB Blaster to a host system, to connect to multiple development systems, for FPGA programming and/or Signal TAP II? Did you run multiple instance...
10 years agoWe've had up to 8 USB blasters connected to the same Linux server with no problem. It should work with Windows too.
Usually I have one separate signaltap instance for each USB blaster I'm connected to, if I need to debug several targets at the same time.
