10 years agoMore than one USB Blaster connected to a host system
Has anyone been successful hooking up more than one USB Blaster to a host system, to connect to multiple development systems, for FPGA programming and/or Signal TAP II? Did you run multiple instance...
10 years agoNote that some USB devices won't work with multiple instances of the same device unless they have unique serial numbers programmed. I don't know if this is true of the USB blaster. If it is, then some of the clones might not have different serial numbers.
