--- Quote Start ---
Ok, good to hear you understand the tradeoffs.
Don't worry, you'll find features of HDL languages that are not supported in Quartus too :)
Perhaps you should ask more questions when you get stuck. If you create code, a testbench, and clearly describe what you are failing to grasp, then the readers of this forum are fairly helpful. If you simply post code that will not even compile, along with too vague a question, eg., "Help, I can get this to compile", usually will not get a response, since its usually because "You're too lazy to read the error messages". If you take the time to ask an intelligent question, you will get intelligent responses.
Cheers,
Dave
--- Quote End ---
Yes, This forum is good with responses to half-intelligent questions, I appreciate that. Sometimes, I'm just completely clueless on how to even approach a problem in VHDL and the building block style of schematic seems like an easier way to go about it.
