10 years agoMoore Finite State Machine questions (VHDL and C)
Hello, I am having some troubles with my Moore state machine. Is it actually possible to use an internal signal or variable dependancy in a IF-statement during a process? Im using a the next...
10 years agoHello Tricky , thanks for your reply. I am aware that I am describing hardware, but I am still a big novice. Im using that waveformgenerator because we used it on my university first time when I came in touch with vhdl/verilog to test easy circuits.
Currently I have a block diagram in my eye's mind how to implement it (reffering to literature). I just like to describe this behaviour I ve mentioned in my first post. Here s a small cutaway for the nextstate logic. --------------------------------------------- state : process(clk,rst) begin if(rst='1') then current_fsm_state<=RESETSTATE; --current_internal_cnt<="00"; elsif(rising_edge(clk)) then current_fsm_state<=next_fsm_state; --current_internal_cnt<=next_internal_cnt; -- -- i have also tried it with that signal assignment to check against it end if; end process; p_output: process(current_fsm_state) begin case current_fsm_state is when RESETSTATE => error_output<='0'; when State_A => -- -- dont wanna spam the complete code end case; end process; ------------------------------------------------------------------ Do u have some ideas how to implement or avoid this scenario?
