9 years agoModifying the c5soc_sharedonly example
I have tried to build the c5soc_sharedonly from the terasic opencl sdk. Qsys creates the needed files with some warnings: Warning: system.acl_iface.acl_kernel_clk.kernel_clk: The input clock frequency must be known or set by the parent if this is a subsystem. Warning: system.acl_iface.acl_kernel_clk.kernel_pll: kernel_pll.reconfig_to_pll must be exported, or connected to a matching conduit. Warning: system.acl_iface.acl_kernel_clk.kernel_pll: kernel_pll.reconfig_from_pll must be exported, or connected to a matching conduit. Warning: system.acl_iface.hps: "Configuration/HPS-to-FPGA user 0 clock frequency" (desired_cfg_clk_mhz) requested 100.0 MHz, but only achieved 97.368421 MHz Warning: system.acl_iface.hps: 1 or more output clock frequencies cannot be achieved precisely, consider revising desired output clock frequencies. Warning: system.acl_iface.acl_kernel_clk.kernel_clk/kernel_clk.clk_in: kernel_clk.clk_in requires 50000000Hz, but source has frequency of 0Hz Warning: system.acl_iface.acl_kernel_interface: acl_kernel_interface.acl_bsp_memorg_host0x018 must be exported, or connected to a matching conduit. Warning: system.acl_iface.acl_kernel_clk: acl_kernel_clk.ctrl must be connected to an Avalon-MM master Warning: system.acl_iface: acl_iface.acl_kernel_clk_kernel_pll_locked must be exported, or connected to a matching conduit. Warning: system.acl_iface: acl_iface.acl_internal_memorg_kernel must be exported, or connected to a matching conduit. Warning: system.acl_iface: acl_iface.kernel_mem0 must be connected to an Avalon-MM master Warning: system.acl_iface: acl_iface.kernel_cra must be connected to an Avalon-MM slave I opened the acl_iface_system and got three errors Error: acl_iface_system.acl_kernel_clk: Component acl_kernel_clk_noreconfig 1.0 not found or could not be instantiated Error: acl_iface_system.version_id: Component version_id 10.0 not found or could not be instantiated Error: acl_iface_system.acl_kernel_interface: Component acl_kernel_interface_soc 1.0 not found or could not be instantiated Can anybody help me? Do I need to add some paths or files to the project? ThxNo RepliesBe the first to reply
