Altera_ForumHonored Contributor15 years agomodifying pin assignments in Quartus II 10.1 Anyone know of the best way to change pin assignments in Quartus II 10.1? Tried in Pin Planner to change pin assignment locations for some signals. (1.) Tried just changing it to the des...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
