Bala-Mookkiah's avatar
Bala-Mookkiah
4 months ago
Modifying internal components Parameters in a Sub-System Package (QCP)
Hi I followed the instructions in online documents and youtube videos on how to add run_system_script for modifying internal components Parameters of a Sub-System Package (QCP) but so far I am not able to successfully modify it. I m hitting two main issues
1. "No Parameter Found" error when loading the QCP in QSYS. I am using internal parameter name but the system is not able to find it
2. load_component and save_component commands in the script is making the component fail to load in qsys.
Any help will be appreciated
Here is the subsystem package script
package require -exact qsys 25.1
set_package_property NAME "rpss_ssd"
set_package_property DISPLAY_NAME "rpss_ssd"
set_package_property VERSION "1.5"
set_package_property GROUP ""
set_package_property DESCRIPTION ""
set_package_property ELABORATION_CALLBACK elaboration_callback
set_package_property EXTRACTION_CALLBACK extraction_callback
set_package_property UNLOCKABLE true
add_fileset synth_fileset QUARTUS_SYNTH fileset_callback "Quartus Synthesis Fileset"
add_fileset sim_verilog_fileset SIM_VERILOG fileset_callback "Simulation Verilog Fileset"
proc elaboration_callback {} {
enable_all_instances
run_system_script TEXT {
set args $__run_system_script_args_list__
set args_len [llength $args]
for {set i 0} {$i < $args_len} {incr i} {
set param [lindex $args $i]
set val [lindex $args [incr i]]
send_message "Info" "val: $val"
load_component rpss_0
set_component_parameter_value QUEUE_MEM_BASE_ADDRESS $val
save_component
auto_assign_system_base_addresses
sync_sysinfo_parameters
save_system
} [ list ADDR 0x10000 ]
# disable_instance clock_in
# disable_instance reset_in
# disable_instance rpss_0
# disable_instance rtile_dummy_0
proc extraction_callback {} {
extract_modules
proc fileset_callback { output_name } {
generate_all_instances
  • sstrell's avatar
    sstrell
    Did you include the _hw.tcl file under Additional Files when creating the .qcp? All files relating to custom IP must be included in the package.
    FYI, windows key + shift + S for a screenshot will be much easier (and clearer) than taking screenshots with your phone.
  • Hi sstrell,
    Thanks for looking into my issue and prompt response. I tried both QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS, but it didn't help. QUEUE_MEM_BASE_ADDRESS is the internal name, and I should use this according to the document. I attached a screenshot of the RSS_SSD QCP internals. rpss_0 is a custom IP (RTL written by me) with HDL parameters. They are configured and exported correctly, as shown in the _hw.tcl. I tried writing a similar script to existing Intel IPs in the IP catalog, and that worked. I am wondering if I need to do anything special in my custom component to configure the parameters in the qcp system.
    add_parameter QUEUE_MEM_BASE_ADDRESS STD_LOGIC_VECTOR 268435456 ""
    set_parameter_property QUEUE_MEM_BASE_ADDRESS DEFAULT_VALUE 268435456
    set_parameter_property QUEUE_MEM_BASE_ADDRESS DISPLAY_NAME QUEUE_MEM_BASE_ADDR
    set_parameter_property QUEUE_MEM_BASE_ADDRESS WIDTH 32
    set_parameter_property QUEUE_MEM_BASE_ADDRESS UNITS None
    set_parameter_property QUEUE_MEM_BASE_ADDRESS DESCRIPTION ""
    set_parameter_property QUEUE_MEM_BASE_ADDRESS AFFECTS_GENERATION false
    set_parameter_property QUEUE_MEM_BASE_ADDRESS HDL_PARAMETER true
    set_parameter_property QUEUE_MEM_BASE_ADDRESS TRANSFORM_PARAMETER false
    set_parameter_property QUEUE_MEM_BASE_ADDRESS EXPORT true
  • sstrell's avatar
    sstrell
    Can you clarify the structure here? You've created a package named rpss_ssd.qcp. What components are inside this package and how are they connected? Show the New Packaged Subsystem dialog box if you can (right-click the .qcp in the IP catalog and choose to Edit it).
    Or maybe it's as simple as QUEUE_MEM_BASE_ADDR vs. QUEUE_MEM_BASE_ADDRESS.
  • BTW, This is a custom IP component which has verilog style PARAMETERS in the source code
