ModelSim wave.do - extra inputs in Wave window
Hi @LChow3
Do you create a modelsim project and run the "do wave.do" in it? Perhaps you could help to share your simulation flow (steps by step on how to simulate your project).
You may try to type restart at the transcript before you run the .do file.
You may checkout the User Guide below on how to simulate your design.
Quartus Standard: https://www.intel.com/content/www/us/en/programmable/documentation/aym1499789502823.html
Quartus Pro: https://www.intel.com/content/www/us/en/programmable/documentation/yur1496247032051.html
Richard Tan
- LChow35 years ago
I have recorded a video of my simulation flow. But I couldn't upload it here. Can I email it to you?
I didn't use testbench. I use the wave editor in the ModelSim.
There is another problem, see the picture below. Although I have keyed in the input X = 1011, on the wave editor, it shows number 1000. Same problem with input Y = 1001, but the wave editor shows number 1000 again.
- RichardT_altera5 years ago
Hi @LChow3
I have send an email to you, you may send the video by replying in the email.
Hi @LChow3,
The reason you might seeing 1000 instead of 1011 for X is probably due to the wave editor tool limitation as it only read the initial bit value of either 0 or 1. Thus if you put 0111, you will see 0000 instead.
When you save format in wave.do, untick the Waveform formats if you do not want to see extra inputs.
Then add below command in the wave.do to show up the outputs simulation.
add wave -noupdate /adder/s
add wave -noupdate /adder/coutBest Regards,
Richard Tan
