Altera_ForumHonored Contributor15 years agoModelSim undefined initial value Hello, I am trying to do some simple simulation using modelsim-altera and am seeing undefined value for output "result" and it stays like that until 10ns or so into the simulation. Here is the examp...Show Morecounter_sim.jpg128 KB
Altera_ForumHonored Contributor15 years agoThank you FvM! Does the initial block mean anything to ModelSim? Does it ignore it?
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
