Modelsim: "Unable to replace existing ini file"
Sadly, it only works partially. I still get these errors in most cases.
Symptom: If I attempt to manually remove the project.mpf file, or rename it, I get a notice that the file is in use by vsimk.exe and the action is rejected. All user controls are off, I'm running as admin, and I own the folder and everything in it. But vismk.exe has locked the file as "in use" as far as Windows 10 is concerned.
Hi @KCMurphy
Could you try to install Questa Intel FPGA Edition (Q21.3 Pro) that released recently?
See if the issue still persists. It will be hard to fix this in Modelsim Intel FPGA Edition as it will not be supported starting from Q21.3 Pro onwards.
Richard Tan
