Modelsim: "Unable to replace existing ini file"
Hi @mindchasers
If you try to do the simulation using the flow mentioned in the document, will you able to simulate it?
https://www.intel.com/content/www/us/en/programmable/documentation/yur1496247032051.html
Richard Tan
- mindchasers5 years ago
Yes, it simulates fine. The problem is when I try to compile even a simple Verilog file. That's when Modelsim hangs and I see the console errors.
I'm just living with it for now.
- RichardT_altera5 years ago
Hi @mindchasers ,
Hmm... that's weird.
Could you help to share the verilog files and the step-by-step simulation flow that you used, so I could try to duplicate the error from my side?
Richard Tan
