12 years ago
Modelsim "Types do not match"
Hi, I've wrote VHDL code, and also a testbench. Its my first attempt writing testbench so go easy please. I think it's correct but Modelsim keeps giving errors; I have tried numerous times with no joy.
This is top level:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity quarter_round is
        generic(l:integer:=9);
        port(y : in unsigned(127 downto 0);
        z : out unsigned( 127 downto 0)
end quarter_round;
Architecture quarter_round_arch of quarter_round is
component rtleft is
        generic(l:integer);
        port( a: in unsigned( 31 downto 0);
        b: out unsigned( 31 downto 0));
        end component;
        signal y0 : unsigned( 31 downto 0);
        signal y1 : unsigned( 31 downto 0);
        signal y2 : unsigned( 31 downto 0);
        signal y3 : unsigned( 31 downto 0);
        signal i1,i2,i3,i4 :unsigned( 31 downto 0);
        signal j1,j2,j3,j4 :unsigned( 31 downto 0);
        signal z0,z1,z2,z3 :unsigned( 31 downto 0);
begin
        y0 <=y(127 downto 96);
        y1 <=y(95 downto 64);
        y2 <=y(63 downto 32);
        y3 <=y(31 downto 0);
        i1<=y0+y3;
        r1:rtleft generic map(7) port map(i1,j1);
        z1<=j1 xor y1;
        i2<=z1+y0;
        r2:rtleft generic map(9) port map(i2,j2);
        z2<=j2 xor y2;
        i3<=z2+z1;
        r3:rtleft generic map(13) port map(i3,j3);
        z3<=j3 xor y3;
        i4<=z3+z2;
        r4:rtleft generic map(18) port map(i4,j4);
        z0<=j4 xor y0;
             z<=z0&z1&z2&z3;
end quarter_round_arch;
Component 'rtleft' :
library ieee;
  entity rtleft is
        generic (l:integer:=7);
  end rtleft;
  architecture dataflow of rtleft is
        begin
        b<=a(31-l downto 0)& a(31 downto 31-l+1);
end dataflow;
And the failing testbench:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
ENTITY quarter_round_vhd_tst IS
END quarter_round_vhd_tst;
ARCHITECTURE test of quarter_round_vhd_tst IS
COMPONENT quarter_round
    PORT (
    y : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
    z : OUT STD_LOGIC_VECTOR(127 DOWNTO 0)
END COMPONENT;
SIGNAL clk : bit := '0';
SIGNAL reset : bit := '0';
SIGNAL y : STD_LOGIC_VECTOR(127 DOWNTO 0);
SIGNAL z : STD_LOGIC_VECTOR(127 DOWNTO 0);
BEGIN
    DUT : quarter_round
        PORT MAP (
        y => y,
        z => z
    y  <= x"201f1e1d1c1b1a191817161514131211";
PROCESS
    BEGIN
    clk <= '0' ;
    wait for 10 ns;
    z <= y ;
    clk <= '1';
    wait for 10 ns;
    END PROCESS;
END test;
The error in modelsim " Types do not match between component and entity for port "y".
Again, I think the testbench is correct. Looking to input a 128 bit value for y and view the result (of z) on the wave.
