10 years agoModelsim Simulation VHO vs VHDL files
I realized there is difference in output obtained from Altera-Modelsim simulation using .vho file (full compilation file from Quartus) and using the vhdl files directly. Any explanations for this ...
10 years ago --- Quote Start --- Have you re-assigned the clock anywhere internally other than the port maps, like:
my_internal_clock_signal <= sys_clk;
Can you post the code for your testbench? Without the code - we can only guess. --- Quote End ---
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
ENTITY SubBytes_TB IS
END SubBytes_TB;
ARCHITECTURE behavior OF SubBytes_TB IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT SubBytes
PORT(
SubBytes_IN : IN std_logic_vector(127 downto 0);
SubBytes_OUT : OUT std_logic_vector(127 downto 0);
SYS_CLK : IN std_logic;
RST : IN std_logic
END COMPONENT;
--Inputs
signal SubBytes_IN : std_logic_vector(127 downto 0) := (others => '0');
signal SYS_CLK : std_logic := '0';
signal RST : std_logic := '0';
--Outputs
signal SubBytes_OUT : std_logic_vector(127 downto 0);
-- Clock period definitions
constant SYS_CLK_period : time := 20 ns;
SIGNAL CORRECT_OUTPUT : std_logic_vector(127 downto 0) := (others => '0');
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: SubBytes PORT MAP (
SubBytes_IN => SubBytes_IN,
SubBytes_OUT => SubBytes_OUT,
SYS_CLK => SYS_CLK,
RST => RST
-- Clock process definitions
SYS_CLK_process :process
begin
SYS_CLK <= '1';
wait for SYS_CLK_period/2;
SYS_CLK <= '0';
end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100 ms.
wait for SYS_CLK_period*10;
SubBytes_IN <= X"193de3bea0f4e22b9ac68d2ae9f84808";
CORRECT_OUTPUT <= X"d42711aee0bf98f1b8b45de51e415230";
Wait for SYS_CLK_period*1;
SubBytes_IN <= X"000102030405060708090A0B0C0D0E0F";
CORRECT_OUTPUT <= X"637c777bf26b6fc53001672bfed7ab76";
wait;
end process;
END;
