10 years agoModelsim Simulation VHO vs VHDL files
I realized there is difference in output obtained from Altera-Modelsim simulation using .vho file (full compilation file from Quartus) and using the vhdl files directly. Any explanations for this ...
10 years ago --- Quote Start --- If the file from Quartus is a netlist, and you get differences in your simulation, then I suggest that you have a problem in your design. Is your design fully synchronous? Does it have lots of asynchronous logic? Have you got all of the appropriate signals in sensitivity lists? --- Quote End --- Hi, thanks for the reply. The design is asynchronous. and yes I do suspect something wrong with my design. Which one reflects the real outcome from my design? The simulation from VHO file or File Simulation. I also realized the waveform from VHO Simulation is one cycle delayed compared to the simulation directly from VHDL File :(
