12 years agoThe ADC's SPI data are first driven by the falling edge of the FS signal, then each falling edges of SCLK which speed is equal to clk_reg. That is, the ADC sends out data on falling edga of clk_reg, and the state machine reads data on rising edge of clk_reg. The system clock (clk_reg) has period of 40 ns (25 MHz). Therefore, there are 20 ns for the ADC new data delay (tPPDO 17 ns max), and > 20 ns For the first bit delay (tDMSB 12 ns max).
The ADC SPI timing diagram: https://www.alteraforum.com/forum/attachment.php?attachmentid=7748 When read data from PC IO (state_read), We need to check signals only when bs_reg and rd_reg are both low, so we need to watch and let only bs_reg and rd_reg in the sensitivity list. We also tried to disable the state_read, let result of read SPI data output to data bus, and confirmed the state_read does not affect the problem of data shift. Most of the latches left in the state_machine are consider as required. However we continue to review those code which maybe hide problem. Thank you for help!
