12 years agoThe test bench : adc01_tb.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity adc01_tb is
end adc01_tb;
architecture behavior of adc01_tb is
component adc01
port (
addr : in std_logic_vector (6 downto 0); -- address bus, 7-bit
data : inout std_logic_vector (12 downto 0); -- data bus
rd : in std_logic; -- read me, active low
wr : in std_logic; -- write me, active low
bs : in std_logic; -- board select, active low
hwst : in std_logic; -- hardware start command
convst : out std_logic; -- conversion start
-- stby : out std_logic; -- standby mode, active low
reset : out std_logic; -- reset ADCs, active high,pulse width > 50 ns
sclk : out std_logic; -- SPI SCLK
fs : out std_logic; -- SPI SS, active low, ADCs' frame synchronization
miso : in std_logic_vector (63 downto 0); -- SPI MISO
busy : in std_logic; -- DAC busy, active high
clk : in std_logic -- system clock
end component;
-- signal addr : std_logic_vector (7 downto 0) := (others => '0');
signal addr : std_logic_vector (6 downto 0);
signal data : std_logic_vector (12 downto 0);
signal rd : std_logic := '1';
signal wr : std_logic := '1';
signal bs : std_logic := '1';
signal hwst : std_logic := '1';
signal convst : std_logic;
-- signal stby : std_logic;
signal reset : std_logic;
signal sclk : std_logic;
signal fs : std_logic;
signal miso : std_logic_vector (63 downto 0) := (others => '0');
signal busy : std_logic := '0';
signal clk : std_logic := '0';
signal test_data_1 : std_logic_vector (31 downto 0) := x"040003ff";
-- Special purpose Addresses --
constant ADDR_STATUS : integer := 0;
-- constant ADDR_CMD : integer := 0; -- The command register
-- Command --
constant CMD_CNVST : integer := 1; -- Start conversion
constant CMD_RESET : integer := 8191; -- Reset ADCs, for 12-bit data bus
constant CLK_PERIOD : time := 40 ns; -- 25 MHz clock
begin
uut : adc01 port map (
addr => addr,
data => data,
rd => rd,
wr => wr,
bs => bs,
hwst => hwst,
convst => convst,
-- stby => stby,
reset => reset,
sclk => sclk,
fs => fs,
miso => miso,
busy => busy,
clk => clk
clock : process
begin
clk <= '0';
wait for CLK_PERIOD/2;
clk <= '1';
end process;
stimulus : process
begin
-- Reset
-- wait for 11 ns;
-- addr <= std_logic_vector(to_unsigned(ADDR_CMD, addr'length));
data <= std_logic_vector(to_unsigned(CMD_RESET, data'length));
wait for 13 ns;
bs <= '0';
wr <= '0';
wait for 50 ns;
wr <= '1';
bs <= '1';
wait for 100 ns;
-- Start convert
data <= std_logic_vector(to_unsigned(CMD_CNVST, data'length));
wait for 13 ns;
bs <= '0';
wr <= '0';
wait until convst='1';
wait for 25 ns; -- -+
busy <= '1'; -- |
wait for 50 ns; -- -+- The max convertion time is 1.33 us
busy <= '0';
wr <= '1';
bs <= '1';
wait for 100 ns;
-- Reset
wait for 200 ns;
wait for 50 ns;
bs <= '0';
wr <= '0';
wait for 50 ns;
wr <= '1';
bs <= '1';
wait for 100 ns;
-- Start convert
wait for 13 ns;
bs <= '0';
wr <= '0';
-- or hardware start
--hwst <= '0';
--wait for 50 ns; -- -+
busy <= '1'; -- |
wait for 25 ns; -- |
wr <= '1'; -- |
--hwst <= '1'; -- |
wait for 1280 ns; -- -+- The max convertion time is 1.33 us
busy <= '0';
wait until fs='0';
wait for 12 ns; --TDMSB
for i in 0 to miso'length -1 loop
miso(i) <= test_data_1(31);
end loop;
test_data_1 <= test_data_1(30 downto 0) & '0';
for j in 0 to 30 loop
wait until sclk='0';
wait for 17 ns; -- TPDDO
end loop;
wait until sclk='1';
end loop;
wait for 100 ns;
-- Read data
data <= (others => 'Z');
addr <= std_logic_vector(to_unsigned(ADDR_STATUS, addr'length));
wait for 7 ns;
bs <= '0';
rd <= '0';
wait for 50 ns;
rd <= '1';
wait for 50 ns;
for i in 0 to 127 loop
addr <= std_logic_vector(to_unsigned(i, addr'length));
wait for 8 ns;
rd <= '0';
wait for 50 ns;
rd <= '1';
wait for 50 ns;
end loop;
wait for 200 ns;
bs <= '1';
wait for 2 us;
end process;
end;
