13 years ago --- Quote Start --- It is good to use this language, But meanwhile show here way to use Verilog, because I want to use this, even I've great command on this language.. --- Quote End --- Verilog is no longer ... its now called SystemVerilog :) If you want to see a very simple example of SystemVerilog testbenches, please see this tutorial on the AlteraWiki: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
