Shainy
5 years agoModelsim Simulation error
I've been trying to simulate an IP core on Modelsim. The IP core I'm using is ALTFP_MULT IP core (floating-point multiplier), with double precision and an output latency of 5(the lowest latency...
Shainy
5 years agoHi @sstrell ,
Thank you so much for your reply! I tried to toggle the switch, with the following modified code, but still I have the same issue. Is there anything else that I've done wrong or maybe there's anything more I should add?
`timescale 1 ps / 1 ps
module fpmulttrial_tb();
reg [63:0] dataa, datab;
reg clk;
wire [63:0] result;
fpmult1try UUT( .dataa(dataa), .datab(datab), .clock(clk), .result(result));
always
#100
clk= ~clk;
initial begin
clk=1;
dataa= 000;
datab= 10.97;
#100
dataa= 7;
datab= 19.97;
#100
dataa= 9;
datab= 109.7;
#100
dataa= 10;
datab= 1.97;
#100
dataa= 4;
datab= 1.7;
#100
dataa= 9;
datab= 19.9797;
#100
dataa= 3;
datab= 9.7;
#100
$finish;
end
endmodule
Thanks a bunch!
Shainy
