11 years agoModelSim shows "wrong number of args for "dataset info"" - Error
I am new to Modelsim and wanted to simulate the successfull compiled vhdl-file from the tutorial:
LIBRARY ieee ; USE ieee.std_logic_1164.all ; ENTITY switch IS PORT (x1,x2 : IN STD_LOGIC; f : OUT STD_LOGIC ) ; END switch ; ARCHITECTURE LogicFunction OF switch IS BEGIN f <= ( x1 AND NOT x2 ) OR (NOT x1 AND x2 ) ; END LogicFunction ; The files are stored in C:\DT and Quartus refused to open ModelSim (Programm not found). But the programm is installed and so I run it seperately and opened C:\DT\simulation\modelsim\switch.vho Then ModelSim says# wrong number of args for "dataset info". What do I wrong?
