16 years ago
Modelsim SDF ERROR
HI, I am using the Modelsim 6.5b for the timing analysis, but when I add the SDO file to the similation, an error occurs showing as follow:Loading instances from E:/FPGA/sin/simulation/modelsim/sin_v.sdo# ** Fatal: SDF files require Altera primitive library.
I am using Verilog HDL, and this error never occurs to my teammate who is using VHDL.
THANKS FOR HELP!!!
1 Reply
    it says that it requires altera's primitive library. try adding the library into the vsim when doing simulation:
    vsim -L altera_ver work.<your top level test bench>
