15 years agoModelSim reports type mismatch in SOPC Builder generated Code
I have a problem simulating my SOPC builder generated system. If I compile my design in ModelSim SE 6.5b I get the following errors: --- Quote Start --- # ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "slave_address" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "slave_nativeaddress" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/cmmb_remux.vhd(15323): (vopt-1133) Type mismatch for port "master_nativeaddress" in component "clock_crossing_0" when binding to entity "clock_crossing_0".# ** Error: C:/Workspace/BB_CMMB/clock_crossing_0.vhd(275): Vopt Compiler exiting --- Quote End --- The corresponding code is the following --the_clock_crossing_0, which is an e_ptf_instance
the_clock_crossing_0 : clock_crossing_0
port map(
master_nativeaddress(0) => clock_crossing_0_m1_nativeaddress,
slave_address(0) => clock_crossing_0_s1_address,
slave_nativeaddress(0) => clock_crossing_0_s1_nativeaddress,
);with the following port/signal definitions
signal clock_crossing_0_m1_nativeaddress : STD_LOGIC;
signal clock_crossing_0_s1_address : STD_LOGIC;
signal clock_crossing_0_s1_nativeaddress : STD_LOGIC;
...and component clock_crossing_0 is
port (
-- inputs:
signal slave_address : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
signal slave_nativeaddress : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
-- outputs:
signal master_nativeaddress : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
end component clock_crossing_0;I dont have problems compiling the design with Quartus II 9.1SP1. So the only workaround I see is to compile it in Quartus II and use the generated *.vho in ModelSim. Any other suggestions ? Thanks in advance
