16 years agoA testbench usually has no inputs and no outputs (ie. no port declaration), it justs generates the IO for the unit under test. You would not compile a testbench in quartus, and it would not go into the FPGA.
my testbenches usually start like this:
entity my_ent_TB is
end entity my_ent_TB;
architecture test of my_ent_TB is
begin
end architecture my_ent_TB;
VHDL supports ALOT of stuff that you cant compile in quartus, which is intended exactly for simulation. For example, to generate a clock, you can do this: clk <= not clk after 10 ns; --a 100MHz clk. and for specified inputs: input <= '1', '0' after 1 us, '1' after 2us, '0' after 5us ; --etc. or for more complicated things (like random number input procedure above): assume input_slv is an 8 bit bus:
process
variable seed1, seed2 : positive := 1587437; --any number will do. Different seed value changes the sequence.
variable input_int : integer;
begin
wait until rising_edge(clk);
rand_int(seed1, seed2, 0, 255, input_int);
input_slv <= std_logic_vector( to_unsigned( input_int, 8));
end process;
