10 years agomodelsim problem regarding input initialization
Hello, i recently encountered a problem when simulating in modelsim which was with the outputs not resposnding to the inputs. Then once i initialized all the inputs the outputs responded normal...
10 years agoInstead of using tcl to drive your design, I highly recommend you look into creating a test bench for the design.
