10 years agomodelsim problem regarding input initialization
Hello, i recently encountered a problem when simulating in modelsim which was with the outputs not resposnding to the inputs. Then once i initialized all the inputs the outputs responded normal...
10 years agoTo voidptr. Your post only applies to vhdl. The op might be using verilog where uninitialized signals default to X. Also I think most of what you pirated doesn't really ally to the ops problem.
To the OP. Post your code. Your problem sounds like a code error.
