14 years agoMaybe it's just me, but since you didn't post the code that generates X and Y I'm not sure how the others were able to re-create the problem. In any case, my re-creation (full code posted below) works just fine, no errors reported, sim runs to completion. Modelsim 6.4c.
I suspect that in your simulation there may be a simulation delta delay between 'X' and 'Y' and that there is a delta cycle where X and Y do produce the value of 261. To verify I would suggest putting X, Y and lxn into a list window and observe there whether or not X and Y really are changing on the same delta cycle or not and whether or not X and Y are at values that would create the errent value at the time of the error. Kevin Jennings
Library IEEE;
use IEEE.Std_Logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.Math_real.all ;
entity foofoo is generic(WIDTH_DQ : natural := 9) ;
port(
X : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ;
Y : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0
end foofoo;
architecture rtl of foofoo is
signal lxn : integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ;
constant RANK: integer := 2;
begin
lxn <= X - Y / (2 ** RANK) ;
end rtl;
entity tb_foofoo is
end tb_foofoo;
architecture rtl of tb_foofoo is
constant WIDTH_DQ: natural := 9;
signal X: integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0;
signal Y: integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0;
begin
process
begin
for x1 in 225 to 227 loop
X <= x1;
for y1 in -114 to -112 loop
Y <= y1;
wait for 10 ns;
end loop;
end loop;
wait;
end process;
dut : entity work.foofoo
generic map(WIDTH_DQ => WIDTH_DQ)
port map(
X => X,
Y => Y);
end rtl;
