Modelsim License problem
Over the last months, I was using Modeslim Students edition as downloaded from the Mentor Graphics website. The software stopped working frequently where i had at each failure to re-install it and request accordingly a new license. I might be wrong, but i have noticed that the software fails to load my design as soon as i connect to the internet through a different network provider which happens often while using my laptop. I could not find a solution to this problem; that's why i am considering to install Modelsim which comes with Quartus...there are many versions there; i only need a light Modelsim version to learn VHDL; which version do you recommend? Does the standalone Quartus Modelsim need also a license? has anybody experienced the same problem as described at the start of my message?
Thank you
Kind Regards
- AnandRaj_S_Intel
- You can use the latest version 10.6C.
- Starter Edition not required license.
https://fpgasoftware.intel.com/18.0/?edition=standard&platform=windows&download_manager=dlm3
download ModelSim-Intel FPGA Edition (includes Starter Edition) and install.
Anand Raj Shankar
- Tricky
Afaik, the student edition of modelsim is not free or requires a licence.
The Web edition of modelsim from Intel is free and requires no licence. It is also mixed language.
The only issue is that it will be slower than licenced versions.
- ABS
Hello Anand and Tricky
@Anand, I am installing the software starter edition; this version does not require a license. I expect the license has a fee and not free. I wonder if there is any limitation with this version compared to Modelsim Intel version
@Tricky: Mentor modelsim students edition license is free for 3 months but can be renewed.
Thank you
- ABS
@Anand,
Since my OS is 64 bits, i had to install 2 packages to edit the files in modelsim as it seems it is a 32-bit software.
i tested a small program in vhdl, both compilation and simulaiton worked fine; so thank you. I installed only Modelsim not the rest of Quartus software as I Intend to use Modelsim as a standalone "generic" VHDL simulator
Please let me know if I am missing anything. Thank you
