Altera_ForumHonored Contributor17 years agoModelsim is exiting with code 9 The message is displayed while executing the simulation. 「Modelsim is exiting with code 9」# ** Fatal: (vsim-4) ***** Momory allocation failure. *****# Please check your system...Show MoreModelSim_exiting_with_code_9.jpg183 KB
Altera_ForumHonored Contributor17 years agoDid you try using the -novopt option on your vsim command.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
