8 years agoModelsim hanging trying to compile Stratix IP
Hi folks, I'm in the process of migrating a design from Quartus 16.1 targeting an Arria 10 to Quartus 18.0 targeting a Stratix 10. Trying to port one of the testbenches that uses the hard floating po...
8 years agoI've now resolved this issue with the help of Altera tech support. If anyone else hits this same problem, there is a bug in the generated msim_setup.tcl file (which should get fixed with a patch at some point...) when using the free Modelsim version. To fix the problem, change the line:
return [string match "*ModelSim*Intel FPGA Edition*" [ vsimVersionString ]] to: return [string match "*ModelSim*INTEL*FPGA*EDITION*" [ vsimVersionString ]] This is around line 170 in the file. Hopefully that'll save someone else some pain! Andy
