8 years agoModelsim hanging trying to compile Stratix IP
Hi folks, I'm in the process of migrating a design from Quartus 16.1 targeting an Arria 10 to Quartus 18.0 targeting a Stratix 10. Trying to port one of the testbenches that uses the hard floating po...
8 years agoHi,
If your project is compiled and generated using Quartus 16.1 than you may face such issue when trying to simulate using other versions of ModelSim. Means we have to use the appropriate version of ModelSim w.r.t Quartus version. Hope you are compiling you design and using ModelSim 10.6c with Quartus 18. Can you share the project files? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
