AVasi19
7 years agoModelSim FFT simulation returns nothing but zeros
Hi, I'm having trouble with simulating FFT in ModelSim. Althoug i've asserted all input signals (as shown on figure_1(2019.06.20 20-01-25)), output of FFT stuck at zero. No valids, no SOP/EOP or d...
CheepinC_altera
7 years agoHi,
Thanks for Nicol for the explanation on the reset.
@Vasilchenko,
You can try the reset as recommended by Nicol.
For your information, you can also generate the FFT example design (simulation) from the FFT IP -> Generate -> Generate Example Design. You can then run the simulation for the example design and cross check with yours to see if can spot any anomaly.
Chee Pin
