8 years ago
modelsim Error: (vlog-13036) near "--": Operator only allowed in SystemVerilog.
After trying to simulate (with no success for now) Arria10 fifo with Quartus 18 Standard installation and modelsim altera starter edition in linux: https://www.alteraforum.com/forum/showthread.php?t=59117
I've jumped to use Quartus 18 Pro edition with modelsim Intel FPGA Edition 10.6c.
Despite the awful surprise that there is no more simple button for simulation, I've followed the Intel Simulation Quic-Start for Modelsim* - Intel FPGA Edition, and after some complications like " modelsim doesn't like '\' as folder separator(default in windows)" and other minor problems, I get to the error shown in the copy of the transcript I left here. I also add the code.
Guillermo
MODELSIM TRANSCRIPT
...#  Model Technology ModelSim - Intel FPGA Edition vcom 10.6c Compiler 2017.07 Jul 26 2017#  Start time: 19:29:03 on Jul 02,2018#  vcom -reportprogress 300 D:/LHCb/Arria10Tests/fifoTest/fifo4fifoTest1/fifo_180/sim/fifo4fifoTest1_fifo_180_kjud6dq.vhd -work fifo_180 #  -- Loading package STANDARD#  -- Loading package TEXTIO#  -- Loading package std_logic_1164#  -- Compiling entity fifo4fifoTest1_fifo_180_kjud6dq#  -- Compiling architecture SYN of fifo4fifoTest1_fifo_180_kjud6dq#  End time: 19:29:03 on Jul 02,2018, Elapsed time: 0:00:00#  Errors: 0, Warnings: 0#  Model Technology ModelSim - Intel FPGA Edition vcom 10.6c Compiler 2017.07 Jul 26 2017#  Start time: 19:29:03 on Jul 02,2018#  vcom -reportprogress 300 D:/LHCb/Arria10Tests/fifoTest/fifo4fifoTest1/sim/fifo4fifoTest1.vhd -work fifo4fifoTest1 #  -- Loading package STANDARD#  -- Loading package TEXTIO#  -- Loading package std_logic_1164#  -- Loading package NUMERIC_STD#  -- Compiling entity fifo4fifoTest1#  -- Compiling architecture rtl of fifo4fifoTest1#  -- Loading entity fifo4fifoTest1_fifo_180_kjud6dq#  End time: 19:29:03 on Jul 02,2018, Elapsed time: 0:00:00#  Errors: 0, Warnings: 0#  Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017#  Start time: 19:29:03 on Jul 02,2018#  vlog -reportprogress 300 -work work D:/LHCb/Arria10Tests/fifoTest/fifoTest1TB.vhd #  ** Error: (vlog-13036) D:/LHCb/Arria10Tests/fifoTest/fifoTest1TB.vhd(1): near "--": Operator only allowed in SystemVerilog.#  ** Error: (vlog-13069) D:/LHCb/Arria10Tests/fifoTest/fifoTest1TB.vhd(1): near "--": syntax error, unexpected --, expecting class.#  End time: 19:29:03 on Jul 02,2018, Elapsed time: 0:00:00#  Errors: 2, Warnings: 0#  ** Error: C:/intelFPGA_pro/18.0/modelsim_ae/win32aloem/vlog failed.#  Error in macro ./msim_setup.do line 33#  C:/intelFPGA_pro/18.0/modelsim_ae/win32aloem/vlog failed.#      while executing#  "vlog -work work D:/LHCb/Arria10Tests/fifoTest/fifoTest1TB.vhd"
TESTBENCH
--library ieee;
--use ieee.std_logic_unsigned.all;
--use ieee.std_logic_1164.all;
--use ieee.std_logic_textio.all;
--use ieee.numeric_std.all;
--library STD;
--use STD.textio.all;
--library altera;
--use altera.all;
--use work.all;
library ieee;
USE ieee.std_logic_1164.all;
entity testbench is
end testbench;
architecture behave of testbench is
    component Arria10FifoTest1 IS
        PORT(
            nReset        : in std_logic;
            ClkIn            : in std_logic;
            DataIn        : in std_logic_vector(23 downto 0);
            DataInValid : in std_logic;
            ClkOut         : in std_logic;
            DataOut        : out std_logic_vector(23 downto 0)
    END component Arria10FifoTest1;
    signal nReset    : std_logic := '0';
    signal ClkIn    : std_logic := '0';
    signal ClkOut     : std_logic := '0';
    signal DataInValid : std_logic;
    signal DataIn : std_logic_vector(23 downto 0);
    signal DataOut : std_logic_vector(23 downto 0);
    constant PERIOD_ClkIn  : time := 5 ns;
    constant PERIOD_ClkOut : time := 4 ns;
begin
    tbu0 : component Arria10FifoTest1 port map(
        nReset        => nReset,
        ClkIn            => ClkIn,
        DataIn        => DataIn,
        DataInValid => DataInValid,
        ClkOut         => ClkOut,
        DataOut        => DataOut
    genClkIn : process (ClkIn) begin
        ClkIn <= not ClkIn after PERIOD_ClkIn/2;
    end process;
    gen_clock_usb : process (ClkOut) begin
        ClkOut <= not ClkOut after PERIOD_ClkOut/2;
    end process;
    rst_gen: process
    begin
        nReset <= '0';
        wait for PERIOD_ClkIn * 5;
        nReset <= '1';
        wait;
    end process rst_gen;
    gen_aux_data : process
    begin
        DataIn <= (others => '0');
        loop
            wait until (ClkIn'event and ClkIn = '0');
            DataIn <= std_logic_vector(unsigned(DataIn) + 1);
        end loop;
    end process;
end behave;
TOP LEVEL
LIBRARY ieee;
--use IEEE.STD_LOGIC_1164.all;
use IEEE.numeric_std.all;
ENTITY Arria10FifoTest1 IS
    PORT(
END Arria10FifoTest1;
architecture beh of Arria10FifoTest1 is
    component fifo4fifoTest1 is
        port (
            data    : in  std_logic_vector(23 downto 0) := (others => 'X'); -- datain
            wrreq   : in  std_logic                     := 'X';             -- wrreq
            rdreq   : in  std_logic                     := 'X';             -- rdreq
            wrclk   : in  std_logic                     := 'X';             -- wrclk
            rdclk   : in  std_logic                     := 'X';             -- rdclk
            aclr    : in  std_logic                     := 'X';             -- aclr
            q       : out std_logic_vector(23 downto 0);                    -- dataout
            rdempty : out std_logic;                                        -- rdempty
            wrfull  : out std_logic                                         -- wrfull
    end component fifo4fifoTest1;
    signal fifoRempty,fifoWfull : std_logic;
    signal fifoRreq,fifoWreq : std_logic;
    signal DataBuff : std_logic_vector(23 downto 0);
begin
    u0 : component fifo4fifoTest1 port map (
        data    => DataIn,    --  fifo_input.datain
        wrreq   => fifoWreq,   --            .wrreq
        rdreq   => fifoRreq,   --            .rdreq
        wrclk   => ClkIn,   --            .wrclk
        rdclk   => ClkOut,   --            .rdclk
        aclr    => nReset,    --            .aclr
        q       => DataOut,       -- fifo_output.dataout
        rdempty => fifoRempty, --            .rdempty
        wrfull  => fifoWfull   --            .wrfull
    fifoRreq <= '1';
    fifoWreq <= DataInValid;
--    inl : process(nReset,ClkIn) begin
--    if ( nReset = '0') then
--        DataBuff <= (others => '1');
--    elsif rising_edge(ClkIn) then
--        DataBuff <= DataIn;
--    end if;
--    end process;
--    outl : process(nReset,ClkOut) begin
--        DataOut <= (others => '1');
--    elsif rising_edge(ClkOut) then
--        DataOut <= DataBuff;
--    end if;
--    end process;
end beh;
    you're compiling a VHDL file using the verilog compiler (vlog). You need to use vcom to compile VHDL files.
    Yes!! Thank you
    Also I had to change the file included to the one that was in the sim folder of the IP module
