10 years agoModelsim ERROR: No extended dataflow license exists
Hi guys i am running a project for some school work on quartus 15.1.
The compilation is ok, test bench is ok, but when i run modelsim appears this error:# ERROR: No extended dataflow license exists# do Microprocessador_run_msim_rtl_vhdl.do# if {} {# vdel -lib rtl_work -all# }# vlib rtl_work# vmap work rtl_work# Model Technology ModelSim ALTERA vmap 10.4b Lib Mapping Utility 2015.05 May 27 2015# vmap -modelsim_quiet work rtl_work # Modifying /home/altera_lite/15.1/modelsim_ase/linuxaloem/../modelsim.ini Vhdl files seems ok and i didnt find information about this error. :( Help would be appreciated. i didnt found anything about this error.1 Reply
It seems like Dataflow view is enabled by default in your case, just disable the Dataflow view and you should not see the Error .
You can find it in Modelsim menu View > Dataflow view Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation)
