10 years agoModelsim ERROR: No extended dataflow license exists
Hi guys i am running a project for some school work on quartus 15.1. The compilation is ok, test bench is ok, but when i run modelsim appears this error: # ERROR: No extended dataflow li...
8 years agoIt seems like Dataflow view is enabled by default in your case, just disable the Dataflow view and you should not see the Error .
You can find it in Modelsim menu View > Dataflow view Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation)
