10 years agomodelsim error 211
We have various versions of Quartus and modelsim (all the free web versions, including 15.1 downloaded yesterday) installed on several PCs and modelsim was working until recently, however on all PCs,...
10 years agoIt seem strange, as it is all ok for me.
try copying to code to a different folder where there is no exitisting work library and try again. With your current attemp the work library has already been set up and may be whats causing the crash. If it still crashes in a fresh folder, then I assume its a problem with your system as it is ok here (and the fact it crashes on multiple versions) You can delete the work library with: vdel work
