10 years agomodelsim error 211
We have various versions of Quartus and modelsim (all the free web versions, including 15.1 downloaded yesterday) installed on several PCs and modelsim was working until recently, however on all PCs,...
10 years ago --- Quote Start --- The Modelsim Reference Manual Lists all of the exit codes Basically, Modelsim has crashed. It is probably something in your code causing the crash (when it shouldnt). I see you are compiling with the -2008 vhdl switch. Any chance you can post all the code here so we can try? Otherwise you'll need to raise a ticket with Mentor (and you wont see an update until altera issue a new version). --- Quote End --- Tricky thanks for the quick reply but I have tested files which I know worked before. I have zipped an example project to a zip folder but the attachments function will not let me load it.
