12 years ago --- Quote Start --- The most obvious thing I would recommend reconfirming is that you have been installing "Altera Starter Edition", not "Altera Edition". I have Modelsim-ASE installed on WinXP on several machines and have not seen this type of issue. I also have several versions of Quartus and Modelsim-ASE installed in virtual machines. Perhaps you can try installing VirtualBox, install WinXP, and then install Modelsim-ASE. You could also file a Service Request directly with Altera and perhaps they might have some other debug suggestions. Cheers, Dave --- Quote End --- Dave, Thanks for getting back. I've confirmed the most obvious things (see included screen shots), and tried a multitude of other combinations. Installing as Administrator made no difference. I've tried the 12.1SP1 variant and several other builds with and without various service pack inclusions. Always done on a fresh install of XP-SP2 (and SP3). All with the same negative result. I've tried it on a completely different PC (AMD vs Intel). Ditto. I tried to post a service request - but had no luck... I need to get in touch with someone that knows the internals. Thanks again.
