13 years agoIt should work fine. Try starting a NIOS II IDE shell (its an option from the start menu) and then type vsim (which is the command-line name for Modelsim).
You might get an error message that will help determine what is wrong. I just installed Quartus 12.1sp1 (including Modelsim-ASE) under Windows XP and it works fine. Cheers, Dave
