10 years agomodelsim compiling error:external function 'xxxxx' may not be used in a constant expr
Consider the following code: package pkg;
function bit bitgen(int bit1idx);
automatic bit res = '0;
if (bit1idx >= 0 && bit1idx < 16)
res = 1'b1;
return res;
endfunction
func...
10 years ago --- Quote Start --- You still have typos. This works for me after replacing end with endinterface. --- Quote End --- Thank you for your patiently replying, At last I found the reason why it didn't work in my design is: one of the functions in the package had declared a local variable without "static" or "automatic" prefix word. But the error message is suppressable for modelsim and is not reported with red color. So this key error message is covered by the following less important red color messages and ignored by me. Now After add a "automatic" prefix for that local variable, the problem has been solved. Thank you for your patient replying again!
