14 years ago
Modelsim compilation error
Hello sir
i am compiling my project in Modelsim PE Student Edition 10.0d it is giving me some errors
it is compiling the whole project except two files mention below# Compile of Input_portx8_package.vhd failed with 2 errors.# Compile of output_fifo.vhd failed with 2 errors.# 10 compiles, 2 failed with 4 errors.
saying failed to open library file input-portx8_package in read/write/execute mode
what could be the error.....
thank you sir
    Looks like it cant find the input_portx8_package.vhd file
    Is this the only error?
    Hello Sir,
    there are two errors
    1 Compile of Input_portx8_package.vhd failed
    for error 1 it says failed to open library file input-portx8_package in read/write/execute mode
    2 Compile of output_fifo.vhd failed
    and for second error it says failed to open library file input-portx8_package/_primary.dat in read mode
    for the first error, its because it cannot find the Input_portx8_package.vhd file. Are you sure the path is correct?
