10 years agoModelsim cannot read .mif file
Hi, I am using a single port RAM IP core from my DE1-SoC board having Cyclone V device. I have initialized the RAM contents with a .mif file. The design simulates in qsim, but, when I try to si...
10 years ago --- Quote Start --- how are you using the .mif file? is it part of a component paramters, via an attribute in your HDL or in the assignments editor>? --- Quote End --- I initialized my Single Port RAM IP Core with the .mif file. In the megafunction manager, I specifies the number of words and the size of each work for my RAM, then, initialized its contens with a .mif file. Then used the symbol for the RAM in my .bdf.
