10 years agomodelsim ase 10.4d/quartus lite 16.0,15.1 on linux source font problem
I can't read vhdl/verilog source because of too small font around 1pt. tools->edit preference->source windows->fixed font or text font size setting change was no effect. This problem is same aft...
10 years ago --- Quote Start --- I second that question. Modelsim 10.4d, solved the freetype2 problem, compiled and symlinked the 32-bit libraries (freetype2-2.5.0.1-1-i686). Modelsim starts with no warnings but the source window font is not readable (very small). I can't find a solution online, would someone at Altera point us in the right direction? --- Quote End --- same here. vsim command put no error message on terminal. It seems it's good to follow the altera installation manual except vsim source window font. I would like to know if it is the same problem on the supported platform, such as Redhat. I'm going to try CentOS.
