13 years ago
ModelSim ALTSYNCRAM Issues
Hi there,
I use the altera 2-port RAM megefunction in my design holding 4 x 8bits. I have seperate read and write clocks, where the read clock is clocked on negedge and the write is on posedge. When I run in modelsim I get the following error:
# Warning: read_during_write_mode_mixed_ports is assumed as OLD_DATA
Now, I have gone back and changed the megafunction so it is now set to DONT_CARE, however, I still get the same error. I've even set both input clocks to be exactly the same just incase, but it is still the same error. Any ideas?
    I think the clue to this "error", is that its not an error, just a warning - hence the Warning at the start of he sentence. This is to do with how the ram behaves. Given you're using opposite edges of the same clock you wont ever get a read - during write clash. So you can safely ignore the warning (not an error).
    Thank you for your reply.
    This is what I thought. The reason why I was concerned about this error is because when I simulate in ModelSim the simulation stays stuck at 0ns, it doesn't move forward at all and just hangs. Any ideas why this might be happening? Im having this issue when trying to simulate some of my other modules but I'm getting no errors or warnings, nor can I find anything when I google it.
    For clarity, this doesn't happen for every module I try to simulate.
    Here's one other module I'm trying to simulate that has this issue. So far, I've only managed to simulate one module which didn't try to infer RAM/ROM, which might somehow be significant. This is for an ALU with mult and add which stores some constants locally - I've edited it to operate without a clock hoping that might make a different (for the constant storage) but still no luck. I was originally running modelsim through quartus, but I am now running it separately with sv files added to a project. It is within this project I have managed to simulate another module (a PC with a stall command)
    ALU:
    module ALU(
    ALU_Func,
    A,
    B,
    Out,
    Cout,
    //clk,
    SW
    //Input, Output and internal signals
    input logic  ALU_Func;
    input logic  A;
    input logic  B;
    input logic  SW;
    //input logic clk;
    output logic  Out;
    output logic Cout;
    logic  Multout;
    logic  Addout;
    logic  Addinterim;
    logic  Const;
    logic  A2;
    //Conststore conststore(/*clk,*/ALU_Func,Const);
    //Constant Store
    always
    begin
    	case (ALU_Func)
    		3'b000:
    			begin
    				Const <= 8'b01100000;
    			end
    		3'b001:
    			begin
    				Const <= 8'b01000000;
    			end
    		3'b010:
    			begin
    				Const <= 8'b11000000;
    			end
    		3'b011:
    			begin
    			end
    		3'b100:
    			begin
    				Const <= 8'b00010100;
    			end
    		3'b101:
    			begin
    				Const <= 8'b11101100;
    			end
    		3'b110:
    			begin
    				Const <= 8'b00000000;
    			end
    		3'b111:
    			begin
    			end
    	endcase
    end
    //Output Multiplex
    always
    begin
    if (ALU_Func == 3'b000 | ALU_Func == 3'b001 | ALU_Func == 3'b010 | ALU_Func == 3'b011)
    	begin
    	Out = Multout;
    	end
    else if (ALU_Func == 3'b100 | ALU_Func == 3'b101 | ALU_Func == 3'b110)
    	begin
    		Out = Addout;
    	end
    else
    	begin
    		Out = SW;
    	end
    end
    //Multiplier
    always
    begin
    	Multout = Const * B;
    end
    //Adder and constant multiplex
    always
    begin
    	if (ALU_Func == 3'b100 | ALU_Func == 3'b101 /*| ALU_Func == 3'b000| ALU_Func == 3'b001*/) //ALU_Funcs for the addition of b1 and b2
    		A2 = Const;
    	else
    		A2 = A;
    	{Cout,Addout} = {A2,A2} + {B,B};
    end
    endmodule
    Testbench:
    `timescale 1 us / 1 ns
    module testbenchALU();
    logic  ALU_Func;
    logic  A;
    logic  B;
    logic  SW;
    //logic clk;
    logic  Out;
    logic Cout;
    ALU alu(ALU_Func,A,B,Out,Cout/*,clk*/,SW);
    initial
    begin
    clk = 0;
    forever begin
    # 10ns clk= 1;
    # 10ns clk = 0;
    end
    end
    initial
    begin
      ALU_Func = 3'b000;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 10ns
      ALU_Func = 3'b001;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b010;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b011;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b100;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b101;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b110;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b111;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
     # 20ns
      ALU_Func = 3'b000;
      A = 8'h01;
      B = 8'h01;
      SW = 8'h02;
    end
    endmodule
    none of your always blocks have sensitivity lists - so they are going to loop forever - causing your lockup. you probably need to change it to
    always @(posedge clock)
    You are absolutely right - my always blocks should have been defined as always_comb, thank you :)
